Please help with wireless settings
G
Guest
Guest
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hi everyone
I'm just trying to set up a wireless network at home so my son can
connect to the Internet through my computer (dial up) and can print on
my printer. I've been tearing my hair out trying to get it to work
all afternoon.
I have two Microsoft wireless adapters and they are talking to each
other with good signal strength. They have different computer names
but the same SSID and workgroup, and security is switched off for now.
My son's computer can connect to the Internet through my PC but I
cannot get them to share files and printers at all. I think I
followed the instructions OK and enabled file and printer sharing on
both computers but they cannot seem to see anything in the workgroup
other than themselves. (I have set up a few shared folders on each of
them).
Both PCs are running XP Home SP1 (waiting for SP2 to arrive) and I
have configured them using the Network Setup Wizard so they have
static IP number of 192.168.0.1 for my PC and 192.168.0.20 for my
son's.
Any ideas about what I have missed here? The connections must be
working as they can share the Internet connection, but I'm at a loss
on why the shared folders and printers don't work.
Many thanks for any help and tips.
Best wishes
Sue
G
Guest
Guest
Can you ping your computer from your son's?
If no: resolve this.
If yes: on your son's computer, type:
net view \\192.168.0.1
Post what you see.
Regards,
--PA
"Sue Swaze" <suswaze@hotmail.com> wrote in message news:9e58141d.0409111556.7bcd24b1@posting.google.com...
> Hi everyone
> all afternoon.
> them).
> son's.
> Best wishes
> Sue
G
Guest
Guest
Hi Pavel, thanks for your help.
I tried pinging both ways but the requests are just timing out. Any idea why?
Thanks again,
Sue
G
Guest
Guest
Have you opened Explorer right click on the drive you want to share, click
the 'sharing' tab and enabled sharing. You need to do this for each drive
on each computer to share.
> Hi everyone
> all afternoon.
> them).
> son's.
> Best wishes
> Sue
G
Guest
Guest
Thanks for replying.
The drives are shared out. I think the problem is that the PCs are
not talking to each other properly as they can't ping each other.
Problem is, I don't know why!
Any further help much appreciated.
Sue
Jack
1,276
Hi
Since your son can use the Internet through your computers it seems that on
a basic level the computers can talk via the Wireless.
I would temporarily Switch off ICS and forget about Internet.
Make first a solid Network, once you achieve solid Network, Switch ICS On
again.
Log to this page it has a lot of links to instructions to Windows Network
Settings, and Sharing: http://www.ezlan.net/sharing.html
Jack (MVP-Networking).
news:9e58141d.0409120922.7be4ee76@posting.google.com...
> Sue
G
Guest
Guest
Hello, I think I know what you need to do to see files on you other computer.
First open 'My Computer', then click on 'tools', then click on 'Map Network
drive'. Pick a drive letter in the window that pops up, and the click on the
browse button to find the folders or drive on the other computer that you
want files from.
"Jack" wrote:
> Hi
> again.
> > Sue
G
Guest
Guest
"Sue Swaze" <suswaze@hotmail.com> wrote in message news:9e58141d.0409120031.1fd9a159@posting.google.com...
Ok so there is some basic prob either with tcp/ip settings (that seem correct)
or the wireless is not really working.
It's not quite clear from your 1st post what is your config - are two WLAN cards working in ad-hoc mode?
Have you run the "Home network wizard" or just set manually the fixed IP om both adapters?
Until you get succesfful ping, nothing else will work.
--PA
G
Guest
Guest
Thanks Jack
I had a quick look at the web page and there seems to be lots to try
there. I will post back hopefully when I have sorted it out or
failing that if I still have problems.
I have a couple of quick queries if you could spare a moment to
respond.
On the page it suggests either resetting the TCP/IP stack or
forgetting this and using NETBEUI.
1. To reset the TCP/IP stack, is it as simple as running "netsh int ip
reset resetlog.txt" on both the PCs? If so, sounds like that might be
worth trying first to see whether it helps.
2. It looks like the NETBEUI idea is pretty simple and stands a good
chance of working - are there any disadvantages to this? The "home
network" is never going to grow to more than 3-4 PCs, so size should
be OK. Will NETBEUI work with WinXP SP2 when I install it?
Thanks again for your help on this. I really appreciate the time you
have taken to post a response and hope that it will all be sorted
later today when I get the time to try the fixes.
Best wishes
Sue
"Jack" <www.ezlan.net> wrote in message news:<OFlRmrQmEHA.3432@TK2MSFTNGP14.phx.gbl>...
> Hi
> again.
> > Sue
G
Guest
Guest
Hi Jack
Many thanks for taking the time to post a response. I haven't had
time to do the suggested fixes from the web page yet but hopefully
they will sort out my headaches!
A couple of quick queries on the suggested fixes.
Firstly, is resetting the TCP/IP stack as simple as running the "netsh
int ip reset resetlog.txt" command on both PCs? Can this do any harm
(eg stop the shared Internet connection working)?
Secondly, the NETBEUI idea looks good. Are there any disadvantages to
this? It looks to be well suited to my "home network" of a couple of
PCs, perhaps 1 or 2 more in the future. Is it compatible with WinXP
SP2 if and when I install that?
Thanks again for your help. I really appreciate the time you have
taken to try to help me out, and hope one or other of these fixes will
do the trick. I'll post back either way.
Best wishes
Sue
> Hi
> again.
> > Sue
G
Guest
Guest
Hi Jack
Best wishes
Sue
> Hi
> again.
> > Sue
G
Guest
Guest
Hi Tony
Thanks for taking the time to post a response. I've tried that but
can't see anything on the other computer.
I'm going to try the tips suggested by Jack first and see if that
helps things.
Thanks again.
Sue
Tony Allegra <Tony Allegra@discussions.microsoft.com> wrote in message news:<C1771A42-814D-45C9-A6E0-1A78D8B7A7CF@microsoft.com>...
> want files from.
> "Jack" wrote:
> > Hi
> > again.
> > > Sue
G
Guest
Guest
(Apologies for multiple posts - it didn't look like it sent the first time!)
Sue
G
Guest
Guest
On 11 Sep 2004 16:56:58 -0700, Sue Swaze wrote:
> Hi everyone
> all afternoon.
> them).
> son's.
> Best wishes
> Sue
Sue,
I have exactly the same problem. The PCs share internet connect, but I
can't share folders (PCs can't ping each other). I've spent weeks trying to
sort this problem out, but no luck so far. I've been pulling my hair out in
frustration.
Hope you have more luck and skill than I did.
Good luck.
