Ok seriously stressing so put everything together then checked and double checked everything. Then when i go to turn on for the first boot there was no splash screen and the mem ok light turned on not sure what this means. removed and reseated ram still no luck tried to use 1 stick same problem. Any advice or help idk if maybe the ram is not compatible but before i purchased everything the ram checked out.
intel i5 2500k cpu
corsair 600t case
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Item #: N82E16835103065
Standard Return Policy
$29.99
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Item #: N82E16820231314
Memory Standard Return Policy
$46.99
CORSAIR Professional Series Gold AX750 (CMPSU-750AX) 750W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Modular Active ...
Item #: N82E16817139016
$169.99
Microsoft SIDEWINDER X4 Keyboard
Item #: N82E16823109191
$46.99
Seagate Barracuda ST1000DM003 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148840
$124.99
Logitech G9x Black Two modes scroll USB Wired Laser Gaming Mouse
Item #: N82E16826104261
$67.99
ASUS P8Z68-V/GEN3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Item #: N82E16813131792
$179.99
i-Work OTI-1508 21pc Quick Change Screwdriver
Item #: N82E16896439143
$7.98
ASUS Black Blu-ray Drive SATA Model BC-12B1ST/BLK/B/AS - OEM
Item #: N82E16827135247
$57.99
EVGA 012-P3-1570-AR GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Item #: N82E16814130593
VGA Replacement Only Return Policy
$339.99
intel i5 2500k cpu
corsair 600t case
$29.99
$46.99
$169.99
$46.99
$124.99
$67.99
$179.99
$7.98
$57.99
$339.99
