PLEASE HELP > XP INSTALLATION ISSUES < PLEASE HELP
yeeeeew
11
Hi, desperately need help. i built my system with following specs and when i go to install xp i get to the point where it says 39 min remaining and my pc turns itself off. please help!
Specs:
Mobo: Gigabyte Ma78g-ds3h
CPU: Amd X2 6000 3.1ghz
PSU: iON 2+ 450 watts
Optical Drive: Sony Sata OEM 20x dvd
Ram: Kingston 2gb ddr800
your big problem will be lack of a hard drive
but your small problem is probably that you will have to enter bios and disable AHCI and enable native IDE mode for the sata ports you have the ethereal hard drive plugged in to
With AHCI enabled XP Setup won't even see any SATA HDD, unless you slipstream the AHCI driver into the XP CD or load it with a floppy
