PLEASE HELP (ZOTAC 780 TI AMP SLI BIG ISSUE ) I Don't know what to do
Joacko_1990
11
Hi guys im kind of new in the comunity . Today i finish building my rig with 2 780 ti sli and i have a huge problem . I will show my settings :
I5 3570k at 4.4 ghz : Voltage 1.36 ( Temperatures max 70)
kingston Predator 2x4 : 1333 stock
motherboard z77x-up7
2 geforce 780 ti Zotac amp / with out any oc
Psu Sentey 1000w ltp1000-sm Platinium 83 amp
LG LM7600 resolution 1920x1080 60hz . Hdmi plug
Last nvidia drivers : 340.52
Im playing crysis 3 with only 40% of both gpu making big Frames drops every 10 seconds .
I dont know if the issue is with the Gpu or Cpu . This is Stuttering ? . i will show you some pictures .
In another hands with the heaven benchmark : Gpu both are at 90% 80% but after few minutes ; in some parts the gpu go at 40% 30% making some kind of quick Freeze
Anyone can tell what is my problem ? im really sad and worry for Spending some much money working hard and play like this .
Sorry for my english . Thanks you
Edit : in witcher 3 after few minutes .. my screen keep freeze making wierd noises with the sound of the speakers and one of the gpu go to 0%
Lifestyle comment: If you had to "bleed for this card" maybe 60FPS on ultra settings on one of the most graphically demanding games on the planet is enough and you should sell the second card. Especially since you are gaming at 1080p with a single monitor, having that much graphics horsepower is somewhat pointless.
Otherwise, marc is probably right that at such an extreme of graphics power, and i7 may perform better.
Looks as though that 3570k is pretty much bottlenecked in that part of the game in Crysis 3 "welcome to the jungle" I've tested my 4770k and 4790k extensively in that map probably 6 hours+ total. My average cpu usage after about 20 minutes is around 60% and that's 8 an thread cpu. Look at your cpu cores usage it's close to 100% usage on all cores. My 4790k at times hits 80-90% overall cpu usage in that map, your i5 is hitting 100% more often, since it has 4 cores, no hyperthreading. If you want to eliminate as much cpu bottleneck, get at least an i7, better yet a 6 core cpu. i5 with 2 high end cards is an imbalanced system.
But this is tom's an i5 is a godly processor good enough for everything, even 4 x Titan's :sarcastic: and the 'bestest' there is.
but what about the Freeze in benchmarks with 90% and 80% of the Gpu . You are saying that my i5 3570k at 4.4 ghz cant keep up with all the games ? i play witcher 2 with one gpu . and i can play it Perfect. but when i do Sli.. my frames drops more and i get 30% 40% Gpu usage .
i downgrade the graphics to see what happend with the cpu and is not even at 77% in all cores but the Gpu % is the same .
i cant play with one ! i buy it for 700usd . i bleed for this card . maybe is the motherboard ? RMA for the cards?
This is my performance with 1 780 ti . 55-65 fps : The cpu is perfect. So why would be crashing with 2? people everywhere saids that i5 3570k can handle it perfect. thas why i think maybe is the gpu
Yeah people on tom's said it would be perfect, i5 over here is considered top cpu. I would never recommend an i5 for 2 high end cards, never, it doesn't make sense. It's great for a single high end card, but not when you're pushing 2 high end cards.
