Question Please Help...
afsalabu43
39
I got gskill ripjaws v 2400mhz cl17-17-17-39 ram and I need to overclock it from 2400 to 2800 or 3000.i switched from ryzen to intel a couple of days ago.with ryzen it boots fine without any errors in 3000mhz clock. I used 16-18-18-38 timings in it.but in this motherboard (asus tuf b560 gaming plus wifi) it showing blue screen with same timings.why? (I used 1.35v)
Can you guys tell me best timings for my ram ?
The best timings is the one that works, when overclocking every system is different even with the same hardware, it’s trial and error. A different cpu means a different memory controller and that will determine the best overclock you can achieve. You could have 2 of the same cpu and the RAM could overclock differently.
Brother can you tell me best timing that I can try?
My processor is i5 11400f
