no, but before booting up the pc , make sure the rams are seated correctly or else pc's not gonna start , obviously.So I removed the battery should I remove ram again?
first try and reseat ur rams. then reset the cmosShould I try resetting CMOS? From what I read I should remove a circle looking battery for 10mins is that right?
Should I remove ram then start pc and put back after or put back right away?first try and reseat ur rams. then reset the cmos
SHould I maybe try putting ram to different slots?no, but before booting up the pc , make sure the rams are seated correctly or else pc's not gonna start , obviously.
I did that it didnt do anything I wrote about it abovetry performing a CMOS reset by removing the CMOS battery for 5 minutes, then reinsert it and turn on the pc
