Question Please help ,
Jun 8, 2024
Attempting to build my second pc this time a white build .
After updating my bios i noticed i had s red light on my cpu but before it was all day . Ive tried reseating the cpu all pins are good reseating ram , resetting cmos and soft resetting pins also bios flask back none of the mouse or keyboard works and i got no display
Specs ; Rog strix b650a gaming wifi
Ryzen 7700x cpu
Ak620 deep color wh
Mw2 1 tb stick and
2x16 gb ddr5 ram sticks from tforce
850psu gold
This pc is 4 days old
Try and remove some stress on the cooler's mount, by performing a couple of anti clockwise turns on teh mount. Which two slots are the rams populating on the motherboard? Got a link to the rams?
850psu gold
850W is the advertised wattage of the build. What is the make and model of the PSU?
Reactions: Lanzo williams
850psu gold
Using a c850 from nzxt and the case also , i did the destress on the cooler and swapped rams to a1 and a3 now the light is amber and https://a.co/d/69NHLbN
If I have this right... your mouse and keyboard work in BIOS.
Your mouse and keyboard Don't work when you boot into Windows.
If that's correct, can you boot into Safe Mode and does the M/K work there?
It just lights up currently not getting any display atm and tried bios flash but its holding a green light after first 10 seconds
