Question Please help
Nov 20, 2024
13
Hi I’ve got liquid cooling in my pc but can’t get the Argb lights to work I’m using a hub since my motherboard doesn’t have the argb connection my cooler is the thermalright frozen notte 240 any suggestions what to do
which motherboard? Which hub? where did you connect the hub to?
RGB software installed?
I’ve got the rog strix Z370-H and the hub I’ve got is an off brand hub it says on the the box its called the LF-99 ARGB FAN hub it’s compatible with most argb including ASUS aura I have the armoury crate installed but isn’t detecting anything
