Dear Community
Hi everyone! I am having some difficulties figuring out what the heck is wrong with my computer...
The computer is relatively new, built on 27th of September 2011. The specifications are as follows:
O/S: Windows 7 Pro 64-bit (Installed on SSD)
CPU: Intel i7 2600K
Memory: Corsair Vengence DDR3 (CMZ8GX3M2A1600C8) 2 x 4GB (2 kits) = 16GB in total memory
Video Card: Gigabyte GTX 580 Super Overclock Edition
SSD: Corsair 60gb Force 3
Hard Drive: 2TB Black SATA3
Motherboard: Gigabyte G1.Sniper2
Power Supply: Corsair HX-1050w
Problem:
In the first week of purchase, during startup the computer would hang on 'loading operating system' and just hang, this would force me to restart and then the computer would load up windows with no problem.
The 'loading operating system' error I temporarily fixed by using Windows 7 repair tool cmd and entering the following commands:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
However in later weeks this 'fix' would prove useless as the problem continues again on random start ups.
* Weeks later, new problems popped up. On start up the computer would completely shut down on windows 7 logo, and then start back up again automatically and boot properly.
* On bootup, it would hang on a black screen just before the 'loading operating system' would start, the only thing that would display was the line: -
* Upon restarting from the above, the computer has now twice popped up with the message "Your system has experienced boot failures because of overclocking or changes of voltages".
Now this error message bothers me because I have NEVER overclocked or changed the voltages to anything. I checked the BIOS to see if the Ram was running on default setting and all seems fine. I know that the 2600k requires ram on 1.5 voltage, and that has checked out too.
I ran memtest86 and no errors have occured.
Furthermore, today I was simply going through the Steam library and my computer popped the blue screen. Upon restart the error "Your system has experienced boot failures because of overclocking or changes of voltages" once again poppoed up.
I have no clue what to do at this point. I asked uncle google about my problems and many points lead to a faulty ram stick. Please let me know what you think, my main concern is the overclocking / voltage change error when I have never touched those settings. Or could it be as simple as the motherboard not being compatible with the Ram?
Please help me and let me know your thoughts
Thanks!!!!
Mike.
CPU: Intel i7 2600K
Problem:
Bootrec.exe /FixMbr
Thanks!!!!
Mike.
