G
Guest
Guest
Hi, I have newly built a new gaming PC, It works most of the time, but every now and then when I try to turn it on the system doesn't want to boot up and keeps restarting.
My PC's components are:
Case: BitFenix Prodigy
Mobo: Asus Z97I-Plus (mITX)
GPU: EVGA Geforce GTX 770 SC ACX
PSU: Cooler Master V750 Semi Modular
CPU: Intel i7-4790K
RAM: Kingston HyperX Beast 2400MHz 16GB
There was one thing that I was a bit confused on is if I was meant to plug just 4-pin or 8-pin in the EATX12V power plug. I just plugged 4-pin plug in, which I assume is correct since it works for the most of the time.
Please help me, I am a first time builder and I'm scared to turn my PC on since I don't know if it would damage anything.
CPU: Intel i7-4790K
