Question Please power down and connect pcie (gpu swap issues)
Feb 26, 2019
17
I was running a Asus ROG B450 gaming-F, ryzen 5 2600, and a gtx 1060 3gb and a antec 850w. I bought a 1660ti, so I swapped the 1060 with the 1660ti. The 1060 has a 6 pin connector and the 1660ti has a 6+2 pin. I plugged the 6 and 2 pin connectors, powered on the PC only to get this message: " Power down and connect PcIE connector... " . Should this not be plug and play?
bond16th
19
same problem here, upgraded from a 970 to a 2060, 970 has a 4 plug and 8plug, 2060 only has a 8 plug. Put in the 2060 plug in the 8 plug and get that message. Tried everything. Reinstalled the 970 with both plugs and it works, 2060 I get that message.
Feb 26, 2019
17
My apologies, I am using extension cables for the Pcie 8 pin's and although I plugged in the 8 pins into the gpu, the extension cable did not have all 8 pins plugged in. @rgd1101 thanks for your comment. @bond16th sometimes its the simplest things that you overlook, the things you would never think you would overlook. By the way, is your psu large enough to power a 2070?
bond16th
19
@SalC 1000w I hope so, Question, is it possible that my system is looking for my old card, and knows that the 6 pin is not plugged in, maybe remove the unused plug from the power supply?
Is it possible that changing where the 8pin plugs into the modular PSU, could have a effect?
It just seems weird that I reinstalled my old card (970) with the 8pin and 6 pin and it works, install the new 2060, with just the 8 pin and no go.
17
I doubt that it is the motherboard looking for the old gpu. As for the unused wire.. I dont think that would make the difference, but then again, you never know, and there is no harm in trying.
is the 8 plug that you are using a 6+2? Also is your PSU fully modular or semi-mod?
bond16th
19
@SalC its a full 8 pin, fully modular, every plug comes out.
I'm trying everything before I RMA the GPU, considering my old 970 works like charm.
Also, if I plug in my HDMI to my motherboard and boot with the 2060 installed the system boots and windows in the device manager says it detected problems and shut it down.
bond16th
19
@SalC fixed it for future reference to anyone having this similar issue. Modulars psu, come with adaptors that go from 6 pin to 8 pin to the power supply. I didn't realize in the back of the power supply it was there. so I only had 6 pins going to the 2060.....:rolleyes:
