Please R9 290 HELP!
the R9 290 will peak at 300W Unless you get the vapor X, those things peak at damn near 400W.
So 300W for the GFX Card, your CPU is in the 280W area when overclocked to 4.0Ghz area 1HDD = 5 to 10W 2 sticks of ram 6W every fan 3W and the mobo does 20 to 50W So Right around the 650 mark. There's even some guys on forums who pulled off running a 290 with a 550W PSU. You'll be cutting it close with the 650 but it will do in the long run
but it says here that 750 is recommended
these is my future build
CPU: i5 4690k
MOBO: MSI z97x GAMING 5
RAM: RIPJAW-x (2x8) 2133mhz
SDD: INTEL 530 SSD 120GB SATA3
HDD: WD Black 1TB
OPTICAL DRIVE: ASUS DVDRW DUAL LAYER 24X SATA
CPU COOLER: COOLERMASTER v4 GTS
CASE FAN: 2 piece of COUGAR DUAL-X 120 CF-D12HB
and PSU : CORSAIR HX650 WATTS or 750 (depends on what you will guys suggest)
is my PSU HX650 enough for my future build? eventhough i overclocked?
there is one included in the front.. ill add 1 side and 1 bottom
Recommended PSU Wattage: 685W http://www.extreme.outervision.com/PSUEngine (with CPU overclocked to 4.4ghz an 1.4vcore, and 25% aging capacitors.
you should be ok with that PSU. It's a very high quality PSU (http://www.hardwaresecrets.com/article/corsair-hx650-gold-power-supply-review/1705) that should not have problems when stressed
But if you want to overclock your CPU you should buy a more powerful PSU. If you dont want to overclock it, then 650 will be more than ok.
BTW, I think you should drop the CPU cooler, or at least buy a cheaper one, buy a cheaper ram, and buy an i7-4790k instead.
