Firstly, thanks Tomshardware and its forum, for its patience and help. Because of you all, I can build my PC without worries and full productivity and enjoyment.
I work full-time from my home office, so I'll be using it for everything: from word processing, graphic designing, video editing, to current-generation gaming (but no plans yet for overclocking)
My pc will be on 16 hours every day, switching it off every night.
My budget is not higher than $3,000, excepting if absolutely necessary for PC's life (I prefer longer life, instead of buying upgrades in the future).
Please review and critique it. All suggestions are highly valued, since I made big mistakes with my previous build plan. Here are my specs:
BASE_PRICE:[+2275]
BLUETOOTH:None
CABLE:None
CARE1:Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
CARE2:Cooler Master Thermal Fusion 400 Extreme Performance CPU - Thermal Compound Optimized for Thermal Dissipation [+10]
CARE3: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
CAS:Corsair Carbide AIR 540 w/ USB 3.0, Dual Chamber Direct Airflow, Full Side Panel Window [+10] (Black Color)
CASUPGRADE:None
CC:None
CD:LG 14X Internal Blu-ray Burner, BD-RE, 3D Playback DVD+RW Combo Drive [+17] (Black Color)
CD2:None
COOLANT:Standard Coolant
CPU:Intel® Core™ i7-5820K Six-Core 3.30GHz 15MB Intel Smart Cache LGA2011-V3
CS_FAN:Maximum 120MM Case Cooling Fans for your selected case [+9]
DOCKINGSTATION:None
ENGRAVING:None
ENGRAVING_MSG:
FA_HDD:Vigor iSURF II Hard Disk Drive Cooling System [+21] (3 x Systems [+42])
FAN:Asetek 550LC 120mm Liquid Cooling CPU Cooler - Extreme Cooling Performance (Dual Standard 120MM Fans (Push-Pull) [+8])
FLASHMEDIA:None
FREEBIE_CU:FREE $50 VISA Gift Card with All Intel Core I7 and Intel Core I5 Desktops and Laptops
FREEBIE_VC1:FREE! Metal Gear Solid V: The Phantom Pain Game Coupon [+0]
HD_M2PCIE:None
HDD:512GB ADATA SP900 SSD + 4TB SATA III Hard Drive Combo [+186] (Combo Drive)
HDD2:None
HEADSET:ZALMAN ZM-HPS200 Gaming Headset
HS_HANGER:None
IUSB:Internal USB 3.0 4-Port Hub [+25]
KEYBOARD:AZZA Delta Gaming Keyboard w/ Anti-Ghosting & red backlight [+9]
MEMORY:32GB (4GBx8) DDR4/2400MHz Quad Channel Memory (ADATA XPG Z1)
MONITOR:None
MOPAD:None
MOTHERBOARD:MSI X99S SLI Krait Edition ATX w/ Intel GbE LAN, 4x Gen3 PCIe x16, 2x PCIe x1, 1x M.2, 10x SATA 6Gb/s
MOUSE:AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK: Onboard Gigabit LAN Network
NOISEREDUCE1:Anti-Vibration Fan Mounts [+9]
OS:Windows 10 Pro (64-bit Edition) [+31]
OVERCLOCK:No Overclocking
POWERSUPPLY:850 Watts - EVGA SuperNOVA 850 GS 80 Plus Gold Power Supply [+34]
RUSH:Standard Process Time: Ship within 10 Business Day
SERVICE:STANDARD WARRANTY: 3-YEAR [3 Year Labor, 1 Year Parts] LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SLI_BRIDGE:Standard SLI/Crossfire Bridge
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS:None
TEMP:Aerocool Touch 2000 Dual Bay Touch Screen Fan Control [+39]
TUNING:None
TVRC:None
USBFLASH:None
USBHD:None
USBX:Internal USB Expansion System + Bluetooth & Wireless N Modules [+39]
VIDEO:NVIDIA GeForce GTX 980 Ti 6GB GDDR5 PCIe 3.0 x16 Video Card (Maxwell) (Single Card)
WNC:TP-LINK Archer T8E AC1750 Wireless Dual Band PCI Express Card [+69]
WTV:None
_PRICE: (+2871)
Main questions I couldn't find answers for:
1: For my HDD, should I get 256gb Sandisk + 4tb Sata III Hard Drive Combo (Combo Drive), or the 512GB ADATA SP900 SSD + 4TB SATA III Hard Drive Combo [+186] (Combo Drive)? I need to know their comparison of quality, not just the amount of gigabytes.
2: Is it too much energy, heat, space to have Vigor iSURF II Hard Disk Drive Cooling System [+21] (3 x Systems [+42])? If yes, would it damage my computer?
3: Are these fans good quality: Asetek 550LC 120mm Liquid Cooling CPU Cooler - Extreme Cooling Performance (Dual Standard 120MM Fans (Push-Pull) [+8])? I read to be cautious when building anything with the word "standard".
4: Can I use 32GB (4GBx8) DDR4/2400MHz Quad Channel Memory (ADATA XPG Z1)?
5: 4gbx8 or 8gbx4, for longer life?
BASE_PRICE:[+2275]
BLUETOOTH:None
CABLE:None
CASUPGRADE:None
CC:None
CD2:None
DOCKINGSTATION:None
ENGRAVING:None
ENGRAVING_MSG:
FLASHMEDIA:None
HD_M2PCIE:None
HDD2:None
HS_HANGER:None
MONITOR:None
MOPAD:None
SPEAKERS:None
TUNING:None
TVRC:None
USBFLASH:None
USBHD:None
WTV:None
_PRICE: (+2871)
