[SOLVED] Please review and comment on mitx build
Imacflier
371
26
CASE Thermaltake Core VI
CPU
Intel Core i5-11600K
MB
GIGABYTE Z590I AORUS Ultra
PSU
Corsair RM750x
GRAPHICS
Gigabyte AORUS GeForce RTX 3080 XTREME WATERFORCE
RAM
Silicon Power DDR4 32GB (16GBx2) XPOWER Turbine Gaming 3200MHz
COOLING
Pump&Heat Sink
Swiftech ApogeeDrive II
Radiator
Phobia Xtreme 200
Fan
Thermaltake 200mm Pure 20 Series Black 200x30mm
Need a recommendation on a reservoir, ideally horizontal.
This thing is primarily for gaming and light CAD and will be overclocked as required.
TIA,
Larry
That's a great looking build so far. One thing to consider would be a 5600x based system because for gaming it handily matches or beats the 11600k in most games with a few outliers. Another reason is that a 11600k will dump about 180-220w of heat into your cooling loop which may impact GPU performance a bit. A 5600x really benefits with getting a fast RAM kit and those are coming down in price a lot lately. If you have never tried tinkering around with RAM I would highly recommend it as it shows meaningful gains on AMD systems.
Here are some references;
https://www.tomshardware.com/features/intel-core-i5-11600K-vs-amd-ryzen-5-5600X
Imacflier
371
26
Helper800,
Thanks for the suggestions, but the Ryzen/Intel ship has already sailed: I have the MB and Apogee parts in hand!
Larry
