Build Advice Please review my build - Tower for office use.
Seskoi
11
Hello guys!
A friend of mine asked if I could build him a tower.
The PC will only be used for office use, but need to be future proof. Needs wifi. I'm trying to find the best bang for his buck.
Please let me know if the balance is good between price and performance (not too overkill for his use or if there would be better options)?
I was hesitant that a Ryzen 5 3400G was overkill and maybe I should switch for a Ryzen 3 3200g?
Rich (BB code):
PCPartPicker Part List
CPU: AMD Ryzen 5 3400G 3.7 GHz Quad-Core Processor  ($149.00 @ Amazon)
Motherboard: Gigabyte B450 AORUS PRO WIFI (rev. 1.0) ATX AM4 Motherboard  ($129.99 @ Newegg)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($63.99 @ Newegg)
Storage: Western Digital Blue SN550 500 GB M.2-2280 NVME Solid State Drive  ($64.98 @ Amazon)
Case: Fractal Design Define C ATX Mid Tower Case
Power Supply: Corsair CXM (2015) 450 W 80+ Bronze Certified Semi-modular ATX Power Supply ($71.45 @ Amazon)
Total: $479.41
Generated by PCPartPicker 2020-06-18 08:20 EDT-0400
Thanks a lot for your help!
Thanks for your answer!
Yes I think I'll indeed go with the 3400g.
According to comments on Newegg the motherboard is 3rd gen ready. I'll make sure to send a separate note asking for it!
Cheers!
