I am building my first computer and I am having trouble checking if everything will be compatible. . If you guys can tell me if the build will work or if there are any suggestions/other comments I would really appreciate it. I plan on using Windows 10 as my OS. Thanks ahead of time for any and all help/comments.
Case: VIVO ATX Mid Tower Computer Gaming PC Case / Black Desktop Shell / 3 Fan Mounts, Dual USB 3.0 (CASE-V02)
CPU: Intel Core i5-8400 Coffee Lake 6-Core 2.8 GHz (4.0 GHz Turbo) LGA 1151 (300 Series) 65W BX80684I58400 Desktop Processor Intel UHD Graphics 630
Mobo: MSI Z370-A PRO LGA 1151 (300 Series) Intel Z370 SATA 6Gb/s USB 3.1 ATX Intel Motherboard
GPU: GIGABYTE GeForce GTX 1060 DirectX 12 GV-N1060D5-6GD REV2 6GB 192-Bit GDDR5 PCI Express 3.0 x16 ATX Video Card
RAM:G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Intel Z170 Desktop Memory Model F4-3000C15D-16GVR
SSD: Crucial MX500 250GB 3D NAND SATA 2.5 Inch Internal SSD - CT250MX500SSD1
PSU: Corsair CS Series, CS650M, 650 Watt (650W), Semi Modular Power Supply, 80+ Gold Certified
PCI-E Express Card: QNINE 450Mbps Wireless PCI-E Express Card, WiFi Network Antenna LAN Adapter with 3PCS Antenna for Windows 7/8/10/XP
Fan (x3): ARCTIC F12 Silent - Ultra-Quiet 120 mm Case Fan | Silent Cooler with Standard Case | almost inaudible | Push- or Pull Configuration possible
Thanks again
-DumbNotDeft
Thanks again
-DumbNotDeft
