please suggest a budget power supply for this build.
nakul224
Commendable
Nov 21, 2016
7
hi ....i am completely new to PC building arena
anyways these are my specs
I am going to buy these products within a month
any suggestions for modifications are welcome
my budget is INR 70000 (USD 1020)
CPU -i5 6600K
https://in.pcpartpicker.com/product/gx648d/intel-cpu-bx...
GPU -Gigabyte gtx 1060 windforce 6GB
https://in.pcpartpicker.com/product/7RKhP6/gigabyte-gef...
MEMORY -8X1 corsair 8 GB DDR 4 LPX
https://in.pcpartpicker.com/product/sMbkcf/corsair-memo...
i will buy another 8 gb in 2 months
MOBO - gigabyte z170x gaming 3
https://in.pcpartpicker.com/product/rskwrH/gigabyte-mot...
HDD -WD cavier blue sata 1TB
https://in.pcpartpicker.com/product/MwW9TW/western-digi...
CASE - deepcool Kendomen
https://in.pcpartpicker.com/product/GmGj4D/deepcool-cas...
it comes with 5 preinstalled fans
CPU COOLER- COOLER MASTER HYPER 212X
http://www.amazon.in/Cooler-Master-Hyper-Intel-Processor/dp/B00D2LZ3AG/ref=sr_1_2?s=computers&ie=UTF8&qid=1479731216&sr=1-2&keywords=cooler+master+hyper+212x
OR
deepcool lucifer v2 ( confused between the two)
i am planning to play at 1080p screen on med to high
Please suggest me a suitable budget PSU for this rig....i am not going to do any SLI or crossfire anytime in future....although my mobo do support both SLI & crossfire.... I will surely overclock my CPU when required.
Actually the prices keep fluctuating a lot. You will seldom find them stable over a long period of time. Seasonic S12II is a very good unit and if you get that cheaper you should go for it. This should give you some idea... http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
But make sure you install the cooler or else your chip might get damaged. Beside that your rig is pretty much fine. Addition of a SSD should make it faster though.
You cannot run that cpu without an aft cooler as it doesnt come with one. Refined your build a bit including a cooler, psu and ssd. The SSD included should make your pc superfast in terms of load times adding much more value. Ditch it though if you are tight on budget.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (₹19450.00 @ Amazon India)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler (₹2100.00 @ Amazon India)
Motherboard: Gigabyte GA-Z170X-Gaming 3 ATX LGA1151 Motherboard (₹9499.29 @ Amazon India)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory (₹7142.14 @ Amazon India)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive (₹4075.00 @ Amazon India)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (₹3665.00 @ Amazon India)
Video Card: EVGA GeForce GTX 1060 6GB 6GB SC GAMING Video Card (₹18570.71 @ Amazon India)
Case: Thermaltake Versa H21 ATX Mid Tower Case (₹2734.29 @ Amazon India)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply (₹8358.00 @ Amazon India)
Total: ₹75594.43
Generated by PCPartPicker 2016-11-23 18:13 IST+0530
prices that you quoted are less than actually shown on amazon
actual prices of parts quoted by u on amazon india-
cpu cooler- 2399
mobo- 11900 including delivery charges
memory- 8399
ssd- might install after 2-3 months
vga- 21852
case- 4807 + 5058 delivery charges :ouch::ouch:....delivery charges are more than the actual price of the case itself
i am happy with my rig....the only thing that bothers me is the power supply...
corsair cxm 550 is very expensive here in india....
even seasonic is cheaper
SEASONIC S12II SERIES 620W /80+ BRONZE
http://mdcomputers.in/index.php?route=product/product&product_id=4911
should i go for seasonic? is this psu good for this build?
or any other cheaper alternative is available?
about the cooler i am confused between these three-
deepcool gammaxx 400 (as suggested by u)- INR 2399 from amazon india
cooler master hyper 212x- INR 2990 from amazon india
or deepcool lucifer v2- approx INR 4000 from the local market
which one is good in terms of price to performance ratio?
