[SOLVED] Plecase help me
Jan 24, 2019
Ok so a few days ago my rx 470 arrived and i put IT on my PC and i double checked everything and when i started the PC i saw the monitor has no signal. I think that the prroblem îs that my motherboard îs just to old (almost 10 years old) here are my specs, :
CPU i5 2500
Motherboard medion ms 7728
Psu 700w
Help me please
Does your PC have the UEFI bios or legacy bios? What OS did you have?
Your PC needs the newer BIOS to recognize the newer hardware, so try to update the BIOS first, keep in mind you needs other GPU to do it.
Also if you add the non-OEM GPU into the OEM pc, you may or may not have compatibility problem. Or if your PC had the OEM gpu like the GT530, and you may try to use the DDU to uninstall the old GPU driver first, then shutdown the PC, switch to the new re470 to see what happens. Or try this method from HP support ( if you use the win8 or up) https://support.hp.com/us-en/document/c03653200
If your PC is not compatible to the non-OEM GPU, after you try these, nothing you can do. Build the PC by yourself.
