Question pls help, freeeeze :( :(
Oct 20, 2020
81
when im playing doom eternal, my pc freezes and i have to press the restart button on my case
what do i do, this is annoying :(
pc
asus prime b450mk
ryzen 5 3400g 4.2ghz
hyperx fury rgb 16gb 8*2gb 3066mhz
vega 11 3gb 1500mhz
zalman wattbit 500w 83+ psu
why is it crashing plss :( :(
Flamebrander
Upstanding
Aug 1, 2020
285
37
240
7
You can download a monitoring software like MSI Afterburner. Set up the OSD (on screen display) by finding a guide on how to, and then you should be able to check utilization and temperatures.
Oct 20, 2020
81
okay dude i'll try it, and i set the fans to max speed in the bios, see if that'll help
Oct 20, 2020
81
when playing doom eternal my pc freezes, but idk why, can it be that my hardware is not upto the level?
but i get 80fps at 900p ,medium with vega 11but minimum req is a 1050ti or a 1650
idk the reason or could it be that i just removed my cpu cooler and kept it back just for no reason??
pls just help me diagnose the problem.. :(
DeathHadArrived
177
5
595
my cpu cooler, a wraith spire, i just took it off for uhh "exploration"
and i just screwed it back
if you did, you broke the seal between them and that is the point of the thermal paste is to seal gaps of the CPU die and CPU cooler. I suggest if you didn't put thermal paste that you should put some on the CPU (don't put too much though).
Oct 20, 2020
81
why did the seal break anyways, when we apply thermal paste, we remove the cooler and apply new paste and keep it back so its just the same thing, where is the problem?
Oct 20, 2020
81
We can't even get to that because instead of giving the information that was requested multiple times, you instead removed the cooler for no good reason. So now you've created a new problem that we have to resolve before even looking at your old problem.
umm what information, i'll tell u everything but what is the info u want
DSzymborski
Polypheme
Your temperatures. Instead of providing the temperatures, you removed the cooler for some bizarre reason. And now, by removing something you didn't understand and not replacing it properly, you've introduced additional complicating factors in diagnosing your problem.
