pls help :(( gpu or processor upgrade? :'(
Matt Lawrence
4
hi , can you help me ? im in a tight budget and i can only buy one component . I really dont know what should i upgrade first if my gpu or my proci first?
my build is amd a6 5400k , with gpu inno gt 220.
i can play dota 2 in low to mid , and bf3 and 4 to low . but i want to play more games like saint row the third which is still lag even in a low setting.
I'm thinking of upgrading my gpu from gt220 to Asus Gtx460 just for $50 but im afraid if it might not improve may computer gaming performance. so what do you suggest ? thank you in advance.
How much is your budget and what currency are we talking about? What resolution do you play at? The GTX 460 will be a good upgrade. If you can save more I would recommend something in the $100 range like a used GTX 660 or 760. If you can't save that much then unfortunately you aren't going to get a very enjoyable gaming experience. The Gtx 750ti is really the lowest end card I would recommend. It's a pretty solid entry level card that can run 1080p at low-medium settings and still give you 60fps when paired with a decent CPU.
And I'm still stuck on a GTX 285 SLI set xD, uhm this really depends on how much cash cash you got. You can probably get your hands on a gtx 580$ for about 50-70$ though, and that's a big upgrade from the gt220 look around on eBay though, you might even get a 670
thank you for your quick reply, i have $72 savings equivalent to php 3,000( philippine peso ) and that's all i have, i search for a used gtx 660 and it cost around $139 ( php 6,500 ) , i think computer parts in our country is kinda more expensive 🙁
and another question what if i upgraded my proci to a8-6600k which is $65. do you think it can improve my gaming performance they said that a8 6600k is way better to my a6-5400k and gt 220 combined ? :/ thank you again 🙁
thanks for the reply . yeah, i think that is the best thing i can do. but i want to play the saint row the third with a stable and smooth fps. even with a low setting that would be fine :S or a worth it upgrade if possible :) with the budget of $72:/
yes i search already but i think they didn't ship products to philippines . at it will cost more for the shipping fee :/
