Hello,
I am new to these forums and i come here in need of help =(.
I have recently bought a new mobo and cpu. installed the 2 items, formatted and all tha good stuff. everything worked great for about 2 days. now my sytem runs slower than my old system. which is driving me crazy! the new system is an amd x2 7750 be 2.7Ghz cpu, and the old was an amd sempron running at 1.6Ghz.
When i start the system, the loading screen for windows takes forever. and then when i try to play a game like World of warcraft, it will often lockup in the loading screen of the game. nothing is overclocked. the chipset seems to be very hot, although im sure that is normal. if i turn off the system and let is sit for a while it seems to ok for a bit then pulls the same tricky little "HAHA" act of taking forever and locking up.
I know that this sounds like an overheating problem but nothing is over heating. all temps are in perfectly fine zones.
anyways, heres my set up......
Mobo: Biostar A760G M2+
CPU: AMD Athlon X2 7750 BE
GPU: Geforce 9500GT Verto
HDD: WDC 320G
PSU: Dynex 400w
PLS PLS PLS, i beg of you for your help. if you have any further questions, or i have not provided enough info, pls just ask and i will tell you. i am desperate at this point, and contemplating buying a gallon of gasoline and having a PC bonfire.
HDD: WDC 320G
PSU: Dynex 400w
