hi im looking to upgrade my radeon 6670 and get a gtx 660 but i dont know if it will fit in the case into a dell inspiron 620 case?.any answer would be appreciated.(yes i know i have to upgrade the power supply)
Technically the card should fit assuming that your PCI-e slot isn't too close to the top or bottom of your case. I would be concerned about the size of the new power supply as well. My advice would be to take precise measurements of the area surrounding the PCI-e slot and make sure you have sufficient clearance. Also make sure wherever you buy your equipment from offers exchange/refunds.
FIrst you have to state exactly which form factor you have, on pictures below are shown: Left - Mini Tower (MT), Right - Slim (s)
By the happiness in your voice I presume that you have mini tower. Now, as you could see on my second picture, the space inside is limited bu HDD cage, so if you already got the card and installed may we know the model which fit well?
So the whole community can benefit on your experience.
