G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I am helping a friend who has fried this mobo, seems there is a high
failure rate by reading newsgroups. I am experienced at putting
together PCs from standard components.
If I can get a replacement that fits, I am sure I can get a
better/cheaper/more reliable solution for my friend. What I am missing
is form factor, compatibility with existing CPU & memory,
power/led/switch connections, physical fit into existing case.
Is there someone out there who has a tried and true solution?
Thanks in advance for your help, here are the mobo/CPU/memory specs
from the Dell service tag lookup:
1 6U214 CARD (CIRCUIT), PLANAR (MOTHERBOARD), DIM4550, NETWORK
INTERFACE CARD/CONTROLLERS
1 9U540 PROCESSOR, 80532, 2.0G, 512K, 400, SOCKET N, C1
1 8T914 DUAL IN-LINE MEMORY MODULE, 256, 333M, 32X64, 8K, 184
