Typically you will only have one component at 100%, be it the CPU or GPU. This depends on the load. If you would like to stress your GPU more, you could increase the graphics details slightly, but this could also have an inverse effect, causing the CPU to work more, resulting in lower GPU use. Play with settings to achieve the best CPU/GPU balance for your specific system.
