Y yusuf.rasuman Jan 18, 2019 1 0 10 Jan 18, 2019 #1 Press F1 to contenue not working ...I you clik F1 not supported wil be desplay...
Solution PdxPetmonster Jan 18, 2019 You have to mash that button on some motherboards to get it to work. The second after you reboot it, start hitting it repeatedly.
PdxPetmonster Reputable Mar 14, 2017 217 6 4,815 Jan 18, 2019 Solution #2 You have to mash that button on some motherboards to get it to work. The second after you reboot it, start hitting it repeatedly. Upvote 0 Downvote Solution
