Question Pls help
Mar 7, 2019
35
I got a gpu which is an
XFX r7700 ghost series
And a psu that is an ace 500w output but doesn't have a 6 pin connecter for my graphics card I ordered an adapter that has 2 molex inserts and 1 6 pin exit to plug into a gpu but i don't k ow how many molex cable do I need to plug into the adapter 1 or 2 a simple answer would be greatly appreciated thanks :)
And a psu that is a 750w but doesn't have a 6 pin connecter for my graphics card I ordered an adapter that has 2 molex inserts and 1 6 pin exit to plug into a gpu but i don't k ow how many molex cable do I need to plug into the adapter 1 or 2 a simple answer would be greatly appreciated thanks :)
What exact model is the PSU? However, to answer your question, connect both molex.
This one ?
That is ~ 250W PSU. It is not suitable to be used with a discrete graphics card.
Certainly not with XFX 7700 (this requires a good quality 450W PSU).
Don't use it. You risk damaging your hardware..
