Accidentally plugged laptop charger in ethernet port because I was in a rush, also I connected the power cord to a wall with no ground (in a Cafe), will my laptop be fine?
I would have thought it unlikely the part of the connector carrying power ever made contact with the Ethernet port.Accidentally plugged laptop charger in ethernet port because I was in a rush, also I connected the power cord to a wall with no ground (in a Cafe), will my laptop be fine?
I mean I kind of just placed it inside the ethernet port I'm just paranoid that maybe it got shocked or smthng, don't have money to replace it.they don't even have the same connector, how did you plug into it?
try it and let us know.
Also the laptop is still working, though idk about the ethernet port because I don't have any ethernet cable.they don't even have the same connector, how did you plug into it?
If you don't use one why are you worried?Also the laptop is still working, though idk about the ethernet port because I don't have any ethernet cable.
Just scared that I might have also broke smthng in the inside or also degrade its performance.If you don't use one why are you worried?
