plugging a UPS into a Surge Protector
I'm not electrically literate, but i recall something about plugging a UPS (true sine wave capable) into a surge protector was a bad idea
am i recalling correctly or am i confused? at my age, confusion is a daily factor, so i appreciate any assist on this
TIA
Alltec highly recommends that you plug a UPS into a good surge protector. I strongly recommend the Tripp Lite Isobar surge protector.
Read Alltec Article here: http://alltecglobal.com/articles/importance-spd-protecting-uninterruptible-power-supply-ups/
So does Eaton Power, here: https://switchon.eaton.com/plug/article/176/ups-vs.-surge-suppressor
Interestingly, APC does not recommend a surge protector. Here are their reasons which I don't find compelling. So long as you use properly grounded high quality surge protector before the UPS you will be fine. BTW, APC has less than 500 Joule protection in their UPS units! See APC Opinion: http://www.apc.com/us/en/faqs/FA158852/
In case the URL is moved, here is the Alltec...
Most already have surge protection inside. And then we include numbers. Destructive surges are hundreds of thousands of joules. Read its specification numbers. How many joules does that UPS claim to absorb? Hundreds? So yes, it does have surge protection. And then we include numbers to learn it is near zero surge protection.
Plug-in protecrors may have more joules. Again, read its spec numbers. It also claims near zero protection. Profits are massive when a majority make recommendations by ignoring numbers.
Something completely different is also called a surge protector. This 'whole house' protector has a dedicated wire for the low impedance (ie 'less than 3 meter') connection to earth ground. This solution for tens of times less money (per protected appliance) actually does protect from all types of destructive surges (lightning being one example).
Numbers. A direct lightning strike is maybe 20,000 amps. So a minimal (and many times less expensive) 'whole house' protector is rated for 50,000 amps. Because the only protectors that are effective also do not fail.
Always ignore recommenations without numbers. Without numbers, then near zero protection in a UPS is promoted as 100% protection.
actually, i wasn't asking about surge protection - just trying to recall if my memory was accurate as to a warning posted here in this forum about not connecting a UPS to a surge protector - i don't recall what the possible "conflict" that could occur, but i'm not worried about voltage spikes, etc
Some of the 'dirtiest' power seen by a computer comes from a UPS in battery backup mode. Due to superior protection inside electronics, this dirty power is not harmful. But that same dirty power is problematic to motorized appliances. And can quickly damage near zero (plug-in) surge protectors.
So UPS and protector manufacturers quietly recommend not powering a surge protector from a UPS.
Some numbers. This pure sine wave 120 volt UPS outputs 200 volt square waves with a spike of up to 270 volts. Square waves and spikes are nothing more than a sum of pure sine waves (as taught in high school math). Appreciate from those numbes why a UPS can be harmful to or be harmed by a surge protector.
Also appreciate that if anything needs surge protection, then everything (even the dishwasher and recharging cell phones) need that protection.
If that Schneider Electric 'reason' was correct, then superior filtering inside all electronics would also subvert UPS operation. They must not admit one glaring fact. The output for a UPS is often so 'dirty' as to even be harmful to small electric motors. But if they admitted that, then many who only assume a UPS is 'clean' power, would learn why that is a myth. And why assumptions are exposed by facts with numbers. Sales would be hurt if Schneider admitted that other fact.
Provided was an answer with numbers. A pure sine wave 120 volt UPS outputs 200 volt square waves with a spike of up to 270 volts when in battery backup mode. That will quickly degrade a plug-in protector. In some rare cases, has even created a catastrophic (potential fire) failure. That protector fire was even created in a fire house by the in house generator.
An AC utility demonstrates a UPS output in their Tech Tip 03. On left is 'clean' power when a UPS connects the appliance directly to AC mains. On right is 'dirty' UPS power because UPS has switched to batteries.
http://www.duke-energy.com/north-carolina-business/products/tech-tip-03.asp
Schneider Electric forgets to mention this. Therefore many consumers never learn that UPS power is typically 'dirtiest' when powering from batteries. Useful answers are always tempered by specification numbers.
In case the URL is moved, here is the Alltec article recommending a surge protector for a UPS:
The importance of Surge Protection Devices (SPD) when protecting an uninterruptible power supply (UPS)
APRIL 26th, 2016
“I have a UPS, why do I need an SPD?” For over 15 years this has been a common objection dealt with on a regular basis. Following are some facts about UPS systems and their susceptibility issues, as well as some comments from IEEE.
A UPS provides secondary or backup power in the event of loss of utility power. A UPS protects electrical and electronic systems, process controllers, and data against the loss of the primary power source, which is the utility company.
Many UPS’ incorporate relatively low energy and low pulse life Category A or B surge suppression. This low energy built-in surge suppression may protect the UPS and its connected load from a limited number of small hits, but it should not be relied upon as a surge transient solution. The Institute of Electrical and Electronics Engineers (IEEE) recognized this problem that a networked Transient Voltage Surge Suppression device and UPS TVSS protection is required.
There are two basic types of UPS systems. First is the rotary UPS which has a motor connected to the primary power source, which is used to turn an alternator which generates the AC output to power selected loads, along with a battery bank. The other type is the electronic or static UPS. This type of unit relies upon inverters and rectifiers to generate the AC sine wave and is supported by a bank of batteries to achieve the desired run times. Within this category you find stand-by, line interactive and double conversion types of UPS’.
Transient Susceptibility of the UPS
Protecting the Rotary UPS: Surge protection is recommended at the input to the rotary UPS to protect the motor windings, (and rectifier/charger and inverter when present), static switch, and bypass path to the loads. Additionally, protection at the output is recommended to protect the sensitive loads from the inductive transients developed in the generator inductance and/or inductive loads served by the rotary UPS as these loads are cycled on and off.
Protecting the electronic UPS: Surge protection is recommended at the input to all electronic loads and the UPS is no exception. The AC-to-DC converter, the static bypass switch, and to a lesser extent the DC-to-AC inverter, are all susceptible to transient damage. Sensitive and transient susceptible electronic control circuitry constantly monitors the status of the UPS and the input and output AC power of the UPS. This circuitry is used to determine if the UPS should be delivering power from the batteries and DC-AC converter: or, if the UPS should switch to the bypass mode and deliver AC from the secondary source which is usually the utility AC power. Additionally, when the UPS is in the bypass mode for maintenance or due to failure, the sensitive loads should also be protected against transient disruption, degradation, and damage from the transients appearing on the secondary AC source or utility power.
The IEEE Standard Section 9.11 states that networked SPD protection is needed, and UPS describes SPD protection as follows:
Service entrance protection “… A listed and properly rated TVSS should also be applied to each individual or set of electrical conductors (e.g. power, voice, data) penetrating any of the six sides forming a structure.”
Premise electrical system lightning/surge protection “… it is recommended that additional SPD be applied to downstream electrical switch boards and panel boards if they support electronic load equipment.”
UPS surge protection UPS surge protection: “Lightning and other transient voltage producing phenomena are harmful to most UPS equipment and to sensitive electronic load equipment (e.g. via an unprotected static-switch bypass around the UPS). Therefore, it is recommended practice that both the rectifier-charger input circuit to the UPS and the associated UPS bypass circuits (including the manual maintenance bypass circuit) be equipped with effective Category B TVSS protection as specified in IEEE Standard Section 9.11
IEEE standard assumes that a TVSS protection network is in place when discussing UPS surge and transient protection.
The requirement that the service entrance and downstream switchboards and panel boards are properly protected with TVSS is assumed to be met. Additionally, Category B TVSS protection is required for the rectifier-charger input circuit and the associated UPS bypass circuits.
Built-in UPS transient voltage suppression: Today, many UPS manufacturers provide low level lightning and surge protection. A typical UPS designed to power a computer may claim the UPS passes ANSI/IEEE C62.41-2002 Category A and/or Category B test waveforms. In general, one would assume that the UPS survives these transients, since there is no pass or fail in the ANSI/IEEE C62.412002. The adequacy of this built-in surge suppression to protect the connected load(s), the let-through voltages, the energy handling capability, and the number of hits of a given amplitude for the various transient waveforms that the built-in surge suppression will survive are not in general provided by the UPS manufacturer.
If a protected load is of sufficient value to an organization to protect against power outages with a UPS, the UPS and the vital load should also be protected against transient disruption, degradation, and damage.
Conclusion
A Transient Voltage Surge Suppression unit placed online in front of the UPS will protect the investment in the UPS and the connected computer equipment. During maintenance and downtime on the UPS, the SPD will filter out the transients and surges from the line during the static bypass mode or maintenance by-pass mode of operation, thus protecting the connected computer equipment from damage. The UPS itself will benefit with fewer maintenance problems and less downtime.
With the investment in sophisticated computer equipment and a UPS unit, the customer has already committed to keeping the system operational on a continuing basis. The additional investment in the SPD is minimal by comparison. The additional protection can be significant in terms of preventing even one downtime incident, which at today’s costs can run some companies as much as $78,000 per hour according to studies conducted and published by Computer Technology Review magazine.
To learn more about Alltec’s surge protection devices (SPD), visit our website alltecglobal.com or http://alltecglobal.com/products/surge-suppression/
