Hello, I have an intel d845 mobo. I recently bought a new tower case (with HD Audio front panel) to solve its cpu heating problems. When I plugged in the 10 pin HD audio plug onto the mobo header smoke issued from the front panel when it was turned on. I took it all back to the dealer who told me that I caused the problem and I should have only used a mobo with HD audio with the new case.
Intel's own website claims ac97 is pin compatible with HD audio. Who is correct?
Any help is much appreciated as I have spent hours trying to find a correct answer. I now have a mobo possibly without front panel sound and a damaged front panel audio.
Thanks
Thanks
