So just built a system and having an issue where occasionally plugging in any devices in the usb or audio jack will lock up my computer and force my to do a hard reset. Tested in bios as well and it locks up. Thought at first it might be a grounding issue so I took out the mobo and test up a test bed on a cardboard box and the same thing happened. Next I thought it might be an issue with my case front panel i/o and I happen to have two of the same case so tried it with my other cases front panel headers and same thing happened. Any help or tips would be greatly appreciated. Specs are listed here: http://pcpartpicker.com/p/2BQXJ
Bios is up to date and I did a clean install of Windows 7 Home Premium 64 bit with all of the latest drivers installed.
