Plugging in monitor for a test boot?
BenQ defintiely does make good monitors.
His monitor uses a HDMI connection not USB.
Does your connection look like this?
Okay then the 290 doesn't have a VGA output. VGA is an old standard so try to upgrade to a HDMI lead/monitor if possible.
You'll need a HDMI to VGA adapter which can be found online. Make sure they have good reviews because there are some that won't work floating around.
