plz help getitng low fps in csgo
Having high-end GPU isn't enough for smooth gameplay. You also need to have high-end CPU to match the GPU performance.
Your CPU is outdated and for better gameplay, i suggest you upgrade your CPU.
For example, i3-6100 is low-end Intel CPU according to the today's standards. Here's comparison of your FX-8320 vs i3-6100,
link: http://cpu.userbenchmark.com/Compare/AMD-FX-8320-vs-Intel-Core-i3-6100/1983vs3511
