Plz i need help , my pc does autorestart
MarinosJuve
11
im not good with computers and i guess that in this forum someone will be who will know.. 3 days ago i recorded with Action mirillis a goal from pes 13 but suddenly pes 13 crashed .. so the next day when i started the game , it was playing normal for 15 minutes after it did autorestart after the same thing .. so i uninstall action and other programmes but still the same also i checked if it was only pro 13 but it wasnt , it was far cry 3 too .. sry for the big text and my english.. who can help me god bless him .. ty
The PSU specs will be on the label attached to the PSU. You will have to open the case in order to find this. Running "SPECCY" will give you all info except the PSU info.
Please check the PSU first. I think that the PSU is faulty and cannot supply the power required under load. Get a new PSU between 400 watts and 550 watts depending on the sale price. Seasonic and XFX are good PSUs'
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
Most PC cases have a left side panel that opens via swinging out (hinged at front) or sliding off the back. The PSU will be the metal box with a bundle of cables coming out of it at the upper or lower back of the case.
The aforementioned sticker with all the specs would be on the side of it and visible, barring being mounted upside down, which is only common in bottom mounted PSU cases with no PSU vent beneath the PSU.
What you are looking for are brand, model, and +12v spec. The recommended power for a GT 630 is only 20amp and 350 watt (minimum total system power). Most 450w PSUs have over 20a, but some less, like cheap OEM ones.
It's probably just a Chrome extension you tried and forgot, or inadvertently clicked on.
Click the little 3 horizontal line icon in upper right of Chrome, then Tools, Extensions. If it's there, from the Extensions page you should be able to just click the trashcan icon to the right of it to remove it.
Also, update Google Chrome to the latest version 38. Do not wait for a notification from Google Chrome.
To update the Chrome browser, open a new window and click on the 3 horizontal bars at the top right hand corner. Then select "About" from the drop down menu. Look for the version. If it is a version older than 38, Chrome will start the update process.
ty guys but i have done all of them and its still , the only one i did not its to do 'this' from regedit , sry 4 my english , also guys i have the same problem , after doing format to my pc my game 'pes 13' its still doing autorestart after 4,5 minutes of playing i do not what it is ... i ll try 2 find psu and ill send it
"Turbo x Cerberus" is the name of the computer, not the brand of the PSU. See here - http://www.plaisio.gr/ypologistes-anavathmisi/ypologistes/etoimoi-ypologistes/Turbo-X-Cerberus-G300.htm
The PSU may be rated for 500 watts but at this point we do not know the quality of the PSU, or the brand name.
Here is a PSU Tier list - http://www.tomshardware.com/forum/id-1804779/power-supply-unit-tier-list.html (Tier 1 is the best).
From the symptoms that you described I suspect the PSU. Replace it with this one - http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Power+Supplies-_-N82E16817207013&gclid=Cj0KEQjwh96hBRCnsefbvZrKrpcBEiQAF7oMdPJ1_g5xq-X083hxcsU_xTGtLSfKGw7pait-G4qyrX8aAk7H8P8HAQ
Or get a PSU 450 watts or higher from Tier 1 or Tier 2 list, and replace your present PSU.
so its not good psu ...
i have this pc since 9/2012
also i think i fixed and now and it doesnt autorestart when playing games .. but i do not know what was ... the update of drivers or a setting i changed to ''My computer''...
anyway rly ty for advices guys !! appreciate it...
