I have win 7 64 bit 4gb ram core 2 duo E7500 2.93ghz . My dedicated memory is 0 mb but total memory is 256mb plzz help to increase my dedicated memory.
The igpu has no dedicated ram and you can't change that. It uses system ram. If you want a gpu with dedicated ram you'll need to buy a video card to add to the system, assuming you have an available slot.
You may want to install the graphic drivers for the dedicated memory to reflect correctly. If the drivers were not installed or uninstalled, the dedicated graphics can report zero. If drivers are installed, and still you are facing this issue, provide here some information regarding the issue you are facing and the laptop model number.
