Plzz help me
vaibhavshukla19
plzz help!!
as i run dirt3 game an error shows (minimum of pentium D or athlon 64×2 required) :(
But i have following config core 2 duo @2.80 GHz,3GB RAM, ATI 6670. :eek:
Is my processor not meeting the minimum requirement :??:
If not then how to fix this problem .. plzzzz helpp :sarcastic:
woggy101
66
what motherboard do you use? i might just be as simple as a$60 fix
weaselman
1,146
Do you have the latest version of direct X installed.
I would have a Check on that as old versions can throw up errors like that.
The system specs seem ok enough to run the game.
Also make sure the video driver is up to date for the Ati card your using.
