Plzzz help I have a Nvidia Geforce gt 610 1gb and i wana setup a duel monitor on it
faizanali khanali
I have a Nvidia Geforce gt 610 1gb and i wana setup a duel monitor on it so can you guys help me that am i able to use 2 monitors on geforce gt 610 plzzz help me to solve this......Thanks
Alright so no problem here. Just plug in both monitors. Plug one into the proper port and you will have to get and adapter for the other. If you have two dvi monitors then use dvi cable and then another dvi cable and a dvi to hdmi adapter. What kind of monitors are you using?
Bro right now i have a vga lcd and i will buy hdmi lcd soon
You should be fine then. Use VGA on your current one, and HDMI on the new one.
