PNY 64 gig flashdrive problems
4nuggets
Commendable
Jul 27, 2016
well started to transfer 62 gigs of stuff from one computer to another and in the middle of the process my computer crashed and when i got back into windows it just says usb memory bar use device
Unfortunately, the screenshot is a bit too small to read, but it looks like it's not detected at all. Since you've mentioned that the same thing happens with each computer you've tried the flash drive with, it really does seem like it might have failed. If it was faulty it could've even be the reason for your computer's crash during the data transfer (if you don't have a different explanation).
You should try to RMA it if it's still under warranty.
Hey there.
That's odd. If the only issue is a corrupted file system (as it's usually what one might expect after an interrupted data transfer) you should still be able to get more data about the device than that. Would you please post a screenshot of what you see in Disk Management when you have the flash drive connected to the computer. Here's how to open Disk Management: How to access Disk Management in Windows to manage hard drives.
I'd advise you to try the flash drive with a different device as well, to see if the same thing happens. You could also try downloading its manufacturer's formatting tool (most SD card and flash drive manufacturers offer such tools for their devices) to see if it can recognize it and reformat it so that you can use it normally.
Hope that helps. Please let me know how it goes.
Boogieman_WD
it doesnt read on none of my pcs or laptops
