PNY GeForce 9600GT Fan
Vazareth21
how do you change the fan speed of the PNY GeForce 9600GT? i just got it today and i dunno if it's faulty or not but the fan is constantly going, ever since i installed it :S
What do you mean by "constantly going"?
The fan is supposed to be working full-time (I believe you know that) but if the noise is bothering you and you want to speed-it-down, you might get the GPU overheated.
Also, some cards can be quite noisy, depending on the manufacturer.
To answer your question, you can use nvidia's tools (ntune, that can be downloaded from nvidias website) or other software like rivatunner (google it) and etc...
But, BEWARE of the GPU's temperature if you plan to speed-down the fan, or your new 9600GT will "meltdown"!
Thanks for the information :) i was just asking because my old graphics card didn't always have the fan going either that or it was deadly quiet :) but thanks for your help :))
