PNY GT 430 will it work on my psu?
bearfg9000
30
Hello there, I was looking for a gpu for replacing my onboard intel hd 2000, Here in my country gpus are 2x as expensive, this is the best i can find http://www3.pny.com/font-color999999GT-430-1024MB-PCIefont-P2938C396.aspx,
will it suffice on a slimline pc, with a "500w" psu with 12v (probably a 250w psu), my other stats are
I5 2310 2.9ghz
8gb ram
750 gb hdd
(also will it work for Bf4 at least on the lowest resolution/settings?, or should i get it on xbox ?)
that video card would totally work, just make sure it has a low profile kit included. there is hardly any power requirements on those types of cards. For bf4, I would just get it on the xbox, you would probably only get about 15-20 fps on low settings. unless that sounds playable to you
Well , That´s the best gpu i can find in my country that might fit my slim pc, If i ever found the hd7750 low profile, will it run on my psu?, Upgrading to a new case isn´t in my budget sadly
It depends on the 12v rail of your psu, I believe the requirements for that card is only about 23-28 amps, your power supply probably could. but a 7750 vs a 430 is no contest, the 7750 would beat it performance wise by a landslide
Yeah i know that, sadly they dont bring good gpus to my country, they think a gt 210 is good for gaming just because its 2gb, And the higher end gpus are like $100 more expensive than on newegg/amazon that angers me
