PNY GTX 1060 card performance
That's not true. I have never heard a coil whine in any gigabyte msi cards. My friend had a problem with his palit but I wasn't using it , since that I remember that there was only problem with that card. I've got nothing elese to say. PNY card is manufactured by palit as I think so get the Asus , EVGA , Msi or Gigabyte. The best safe way to make sure that you are good with warranty. Give 10 gbp more and get EVGA or Asus. I recommend them the most.
One more thing there is no 8 gb version of gtx 1060. Get this card it's on sale with a great cooling and warranty. : https://www.amazon.co.uk/EVGA-GeForce-Superclocked-Express-Graphics/dp/B01IOWT538/ref=sr_1_1?ie=UTF8&qid=1496146406&sr=8-1&keywords=evga+gtx+1060
Yes, I've heard about coil whine and it seems even some Gigabyte and MSI have it, not all of them but its a lottery hahaha. Sadly the ones you mention are above my budget (some of them almost $100 more), the next one I can afford above the PNY is the Gigabyte WindForce 8Gb (I've read this also could present some coil whine), but its almost $60 bucks more than the PNY, do you think its worth it ?
You are right, I meant 6gb hahaha, there are a lot of results on google and youtube about coil whine on those cards. But you are right about the warranty, I didnt knew Palit/PNY wasnt a good brand. I'll consider the evga but here in my country on amazon its not available (for 1 or 2 months). My choices are that PNY or the Gigabyte windforce 6gb. I'll guess it will be the Gigabyte.
