point to point radio/network connection
May 21, 2018
Hi, i am looking for a Point-to-Point Gigabit Radio system. 2.4 ghz and 500 mbps atleast. Looking to create a NAS system with a buddy over air line. And we live 300 meter away from each other. So a ethernet cable not do us much… got any tips? Anything is much appreciated. something like airfiber or airmax but a cheaper option.
https://www.simplewifi.com/products/parabolic-grid
There ya go. Browse around their site and see if you can find a better solution, but the most basic parabolic will work better than find for you with normal wi-fi speeds, I don't know about gigabit. I'm not sure you are going to find anything that fast for cheap. The problem will be any trees or anything between the two antennas.
Really you could go from router to router or router to switch with one of these long range antennas and it just be like extending your normal wi-fi.
thank you for your help
