Hello,
There is a problem with the camera reading my SD card.
When i connect it to the Pc
This camera has the software in the memory,and transfers it too SD Card as soon you switched on. The drive F/window pops up and is frozen for about 2 minutes,then disappears.I tried too open with win explorer,but is also frozen i waited several minutes.its not possible too switch the camera of.also my desktop just turns green,when i try too shut down win explorer.I disconneted the camera from the PC by removing the usb cabel.My desktop was back again.Hoever i could not switch the camera off,the green light was allways on i had too reset the camera then the light switched off.I removed the SD card and used a card reader without problems,there have been some files on the Card.I copyed the files too desktop and Polaroid.exe opened with out problems.
using other device like Mobil phone and camera with SD card inserted with out problem. Winxp sp3 latest updates I used 8GB SDHC kingston and Scandisk 2GB both work fine on my Card reader.No other device was connected at the time.
Thanks for any help
Thanks for any help
