Polk Audio TSi100 or Klipsch KB-15
RepTepHoudini
12
Polk Audio TSi100 or Klipsch KB-15, I am looking to buy one of these for my computer/gaming setup. I havn't had luck finding any good speakers for gaming that are great quality and I was able to find a top 10 ebay list for audio and these came up. Here is the amazon link to both
Klipsch KB-15 -https://www.amazon.com/Klipsch-KB-15-4-Inch-Bookshelf-Speakers/dp/B00AS3X740/ref=sr_1_1?s=electronics&ie=UTF8&qid=1499448987&sr=1-1&keywords=Klipsch+B-20
Polk Audio TSi100 - https://www.amazon.com/Polk-Audio-TSi100-Bookshelf-Speakers/dp/B00192KF12/ref=sr_1_3?ie=UTF8&qid=1499449211&sr=8-3&keywords=Polk+Audio+TSi100
The Kiipsch will have punchy bass but brighter highs. The Polks more balanced clearer sound with smoother top end,
The other speakers you link to are twice the price and may be better but since they are made in tine quantities compared the others that adds to their price. The Parts Express kits they are based on might be a good choice for you if you don't mind some assembly at the same price range as the others.
You can also consider the ELAC
https://www.amazon.com/Debut-Bookshelf-Speakers-Andrew-Jones/dp/B014GSEQ06
are they good for gaming. I just looked into audioengine a2+, what would you say>?
