Poor CPU and random read/write performance
thisisnotnew
Commendable
Mar 21, 2016
8
This issue began about a week ago, 2 weeks or so after buying the laptop and upgrading the ssd. First the specs:
My system
  • + Dell XPS 15 9550 laptop
    + OS: Windows 10 Home
    + STORAGE: Samsung SM951 M.2 256 GB PCIe 3.0 SSD (AHCI, not NVMe)
    + CPU: i5-6300HQ
    + GPU: NVIDIA GeForce GTX 960M with 2GB GDDR5
    + Integrated GPU: Intel 530
    + RAM: 8GB DDR4-2133MHz
    + CHIPSET: Intel C230 Series
The problem
I first noticed a new sort of sluggishness while browsing the web. Pages were taking far longer than usual to load, especially images on the pages. This happened no matter the browser, regardless of whether I was on WiFi or an ethernet connection. Speedtests were fast as were sustained downloads. The next place I noticed the slowness was playing a game (WoW) where when I loaded a new area, textures were taking a good 3 to 5 extra seconds to load. Turning down the texture resolution to low improved this issue. The GPU intensive parts of the game were still working fine, just the texture loading had problems.
Because of this I suspected it was an SSD problem. I had installed the SM951 myself after buying it and it had worked beautifully the first two weeks before this happened. Still, this wouldn't explain the slow webpage loading. I ran various benchmarks on various components and what I found was that something was clearly wrong, but it wasn't clear exactly what.
Here's one of the benchmarks (ignore the graphics part of it; it only tested the integrated gpu): http://www.userbenchmark.com/UserRun/901007
This seemed to suggest that my SSD wasn't the issue. Running tests specifically on the SSD I got quite fast sequential read/write speeds (~2000 MB/s) but the random read and write speeds were pretty abysmal. I think this is linked to the slow texture loading, though I don't necessarily think the SSD is the culprit.
It almost looks like the CPU is the issue. I thought maybe it was being throttled in software so I reinstalled Windows, disabled all the power saving capabilities, updated all drivers, booted in safe mode and watched the CPU hit 100% freq and 100% usage during the benchmarks. But still I was getting the slow results you can see in that benchmark (http://www.userbenchmark.com/UserRun/901007).
Non internet-enabled applications also seem slower than usual for what it's worth. Windows Explorer takes just a bit too long to open, etc. Boot times are still relatively quick despite all this.
Summary
  • + Slow browsing
    + Slow random read/write speeds (but fast sequential read/write)
    + Poor CPU performance
Unsuccessful fixes I tried
  • + Checked actual internet speed
    + Made sure SSD was not nearly full (75% free)
    + Checked SSD performance (fast sequential read/write)
    + Watched resource monitor during slow loading event and didn't see anything obviously bottlenecking the process
    + Checked discrete GPU performance and it's still fine (though doesn't show up on above benchmark)
    + Checked performance on battery vs. plugged in
    + Disabled all power saving software like Intel SpeedStep, TurboBoost, and C-States
    + Updated all drivers!
    + Reinstalled Windows 10
    + Tried Windows High Contrast Mode (on the advice of some forum post; obviously didn't work)
Does anyone have any ideas? Do you think it is actually the CPU?
@thisisnotnew PROCHOT is the problem for sure. Tried ThrottleStop and it won't work with the XEON...
Same issue here. Precision 5510 w/ Xeon. Was trying all the same things you did. Windows Server 2012 and Windows 8.1 work great. Definitely a Windows 10 issue. Super frustrating. Probably will just go back to Server 2012.
Just to be clear, my issue was that the CPU was being throttled by a bidirectional PROCHOT flag (which I believe was being sent by my SSD). After opening everything up, dusting everything out, and reseating the SSD and reinstalling Win10, the issue was fixed. Before that, as a temporary fix, I had been using ThrottleStop to block the bidirectional PROCHOT flag. Your issue may be different.
@thisisnotnew PROCHOT is the problem for sure. Tried ThrottleStop and it won't work with the XEON processor. I guess Windows Server 2012 talks better with the Xeon Processor so it can bypass this sensor issue. The problem may be that the processor is stuck in the throttle mode. Going to try and open up the laptop and unplug the battery to try and reset. You may have just saved a Precision 5510 from being tossed out the window. Had to restrain myself multiple times.
Update: 4:00 PM
Unplugging the battery fixed it. Random reads at 4x of what they were previously. Also thermal throttling is now turned off. The 3 month Nvme SSD saga is now over. Thanks for the help
