hey there,
so x265 is out and is supported by handbrake, so i was thinking to use it to convert videos into x265 format
so i took a 720p 30fps 6mbps 30second video and started to convert it into 256kbps ( video bitrate ) x265 format
quality was acceptable considering the bitrate, but it took over 1 hour to do complete the task using 1090t @3.6GHz.
after checking some anandtech's benchmark i found that 1090t/1100t is listed at the bottom of the performance chart ( even slower than A8-6500T 2.1ghz ) http://www.anandtech.com/bench/CPU/1061
considering that 1090t is much faster than 6500t and have more cores too so 1090t should have performed much better than this.
can someone explain why 1090t is so much behind?
does x265 in handbrake use some instruction which are not present in 1090t? if yes then which one ?
