Hey all,
I'm having quite the issue getting my Minecraft port forwarded on TCP and UDP. Used to work fine, then I unset my IP from being static and haven't gotten things back to working since then, even after re-setting the static IP. I'll try to give you a breakdown of my situation:
1) Windows Firewall has been turned OFF
2) DMZ has been DISABLED
3) Added the rule to allow TCP and UDP for port 25565
4) IP on router is STATIC
5) IP on server-running device is STATIC (although, on ethernet, not the same as the router's static IP)
6) I have tried running the app while checking the port to no success
7) I have not tried a hard, physical reset of the router since the port forwarding broke
Let me know if I'm missing anything or should provide any more info - thanks!
