Port Triggering / Port forwarding
STcreature
123
ok so recently ive been trying to port forward BO3 Servers so i can open my nat and have some good matchmaking
i have tons of experience on port forwarding and im pretty sure im doing it right but for some reason one day it stopped working, I have the firewalls in my pc disabled
I also set my pc as a DMZ but nothing worked
I started to think that the problem is from port triggering ive never messed with it or anything
my question is
What is port triggering ? and will it fix my issue if port trigger the ports?
Port triggering requires your PC to initiate an connection on a particular outbound port. When the router detects traffic on that port, it will open up the specified inbound ports to your PC.
Port triggering is only used for certain applications, and usually not for gaming servers. If port forwarding is configured correctly, port triggering will not solve the problem.
