portable lightweight monitor for mini-itx build recommendations?
eazyh
49
Hi,
So im putting together a mini itx build for easy portability. I am looking for the best option for a lightweight portable monitor with at least 17inch screen? any ideas?
Thanks
I dont suggest overclocking in an ITX build without water cooling. Thngs just cook up too much and too much heat that effects other parts is created. As for monitor, the ASUS VX228H is really thin and lite. You do not have those in the UK I dont think so an alternative would be the VX238H. It is larger, I dont know how much weight that adds though.
