Ok guys, so my idea is buidling the something like all in one PC, but from used parts.
My plan is to get some PC case and put monitor to act like its side.
I think that should work, but only problem is that-for example 19 inch monitor "fits" side of ATX case- but PSU is not allowing it to fit in. Is there any workaround for this problem?
Shoud I use smaller monitor (even though only smaller is 17 or 15 inch and I think that won't help much).
Should I try to find some small PSU?
P.S.: One more question is, can I use pcie x16 card in x1 slot?(PC won't be used for gaming or any hard work)
Thanks in advance people!
