Portable PSU for micro-ATX motherboard
corona1
Does anyone know of a portable power supply I can use for an ASRock H77M micro ATX motherboard? It needs to be small, lightweight, and rechargeable (like a laptop battery). The ASRock has a standard 24 pin ATX power connector and an 8 pin power connector. I am looking for something more plug and play than wiring a battery with the correct voltage dividers and pinouts.
Thoughts?
I don't think such things exist. A PSU takes input power from a power source. It then delivers output power in the form of various 12V, 5w etc.
All PSUs are mobile in a sense. You can unplug them from motherboard etc. But it's not very convenient as plug and play.
It should be possible to connect a PSU to a battery of sufficient capacity. That battery would be mobile.
Or you could buy a laptop?
